Others: hardware and software
Using STVD with Cosmic C compiler. A bit in a global variable is being set unexpectedly. How can I prevent that?
I am modifying code for the NUCLEO-8S208RB used with X-NUCLEO-NFC05A1 NFC reader. The code was originally developed by ST. I need to modify it for my own application. So, I created my own global variables and gotten rid of unnecessary code. So far ev...
EBogo.1 by Associate II
  • 1134 Views
How to do RTC calibration (STM8L151F3)
Hi,I am using RTC in WakeUp mode to wake the MCU to save energy.The problem is that the RTC time base is not accurate as I am using LSI on the RTC.Is there any way to make RTC more accurate using LSI as a clock source?.CLK_PeripheralClockConfig(CLK_P...
Leo1986 by Associate II
  • 920 Views
TS555 timer simulation library for LTSpice
Hi all, this is my first post. I called customer service asking to see if there were a simulation library i could use for the TS555 timer, and they recommended I make a post in this forum asking about it. I will gladly go post in another forum if nee...
JSarn.1 by Associate
  • 1253 Views
STVD crashing when I select Tools>Programmer
I'm using the latest version of STVD in Windows 10 (up to date). I'm trying to connect to an ST-LINK V2, but as soon as I select Tools>Programmer, STVD crashes. I also have STVP installed and am able to program my device with it, but I would reall...
KDesr.1 by Associate III
  • 833 Views
