2024-01-25 12:05 AM - last edited on 2024-01-25 12:25 AM by Peter BENSCH
Hi Team,
Currently we are using M24C02-WMN6TP and is in NRND status. Could you please suggest an replacement which is FFF and active in status
2024-01-25 12:35 AM - edited 2024-01-25 12:36 AM
The EEPROM M24C02-WMN6TP has a guaranteed supply voltage range of 2.5V-5.5V.
Both the website and the data sheet for this EEPROM indicate that there are pin- and function-compatible types that operate in a wider voltage range:
You can therefore use the order designations M24C02-RMN6TP and M24C02-FMN6TP as alternative devices.
Hope that helps?
/Peter
Hope that helps?
/Peter
