Others: hardware and software
STM8S003F3 UART IRQ freezes mcu
Posted on November 01, 2016 at 18:44hello everyonebeen playing with that mcu for a while but I cant set up UART IRQ DR(data register) emptyIO pins interrupts work as expected but after setting TIEN in CR2 function enableInterrupts() freezes whole ch...
ST7580 GUI Issue
Posted on May 09, 2017 at 14:59Hi,  Everyone!I'm Sorry about asking  PLC problem on STM32s MCU community.I have bought a PLC evaluation B'd that is STEVAL-IHP007V1 .And  make test enviroment like below.        PC <-- UART -->  STEVAL-IHP007V1  <--->...
I2C setting problem on STM8L101
Posted on April 24, 2017 at 08:39Hi,I have a #I2C setting problem on STM8L101, I am using the ST's ''STM8L10x_StdPeriph_Driver'' library and try to setup the I2C bus to run at standard mode 100KHz (with system clock of 2MHz) for reading a magnetic s...
STVP fails to load \TOOLS.CNF
Posted on April 26, 2017 at 13:58Hi,I've been trying to connect my application through ST-LINK according to the http://www.st.com/content/ccc/resource/technical/document/user_manual/90/cb/42/ef/2e/53/46/75/CD00060186.pdf/files/CD00060186.pdf/jcr:con...
I2C setting problem in STM8L101
Posted on April 24, 2017 at 08:32Hi,I have a I2C setting problem on STM8L101, I am using the ST's ''STM8L10x_StdPeriph_Driver'' library and try to setup the I2C bus to run at standard mode 100KHz (with system clock of 2MHz) for reading a magnetic se...
