2003-10-30 2:45 AM
2003-10-27 11:08 PM
I'm using an externel flash (m25p80), which is connected to my ST7Lite0 via the SPI protocol. Is there any way which i can write & execute program on the flash memory? my app will need more that the 1k byte memory wich i have at the ST7LITE0.. Thanks Itamar2003-10-29 2:26 AM
No, it is not posssible.
Which compiler you are using? You could try optimizing your code. [ This message was edited by: Jatin on 29-10-2003 16:10 ]2003-10-30 1:52 AM
Sorry to hear its not possible..
I'm using the COSMIC compiler, any ideas? thanks itamar2003-10-30 2:45 AM
Hello Itamar ,
Pl's contact me to look for new micro or similar with more memory . Latino - Sherman from IsraelWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
