2006-07-09 9:39 AM
Maximum Stack usage while using Cosmic+ST7
2006-07-06 3:22 AM
* We are using ST72F561R9 with STVD7 IDE & Cosmic Compiler, * We have used SCI & TimerA interrupts, * Memory model used is Short stack 1. The map file shows the stack usage as Please see the attached file. 2. The default stack size of the MCU is 256 bytes. 3. Is 92 shown by the map file, a correct figure or the stack may go beyond that at any particular instance (Nested interrupt requests)? 4. We are using function pointers in our code. Will this affect the stack usage in a hidden way? Regards, Yogesh/Amit ________________ Attachments : Part_of_map_file.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0DW&d=%2Fa%2F0X0000000bVZ%2FRp._eurOCABCZDHIHANdlzauBpIhUVRpp3pyo59_1H8&asPdf=false2006-07-09 9:39 AM
