2003-09-15 12:27 AM
2003-09-15 12:20 AM
Hi
Is it possible to re-program the flash memory of the ST72C334 using the Kanda Keyfob, if the security option has been set to ''No further Read/Write'' in the previous programming? /Ulrich2003-09-15 12:27 AM
The option byte needs to be written to no protection before any programming can be done. Once this option is set, the flash will be erased. SimonWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
