2008-11-14 12:41 AM
How to make board recognized by DfuSe Demonstration?
2011-05-17 12:47 AM
let ''STM Device in DFU Mode'' appears in Available DFU Device of DfuSe Demonstration,2011-05-17 12:47 AM
I have the same question. How can I do that? where are the code? Thanks in advance. ALFA2011-05-17 12:47 AM
Hi ,
The code is here : http://www.st.com/stonline/products/support/micro/files/um0290.zip Then go to ''str91x demos/Device Firmware Upgrade/project/EWARM'' if you are using IAR version 4.42A and program your board using Jlink and JTAG. first. Hope this helps you. ST1 :)2011-05-17 12:47 AM
Hi ! This DfUse application comes with a button to Enter DFU mode/ HID detach and leave DFU mode. Does anyone have a example of a HID firmware with DFU support, I mean a HID/DFU compliant device?
