2004-09-16 2:44 AM
2004-09-15 6:04 PM
dear sjo,
I have maked one FLASHBASH(use St72C264G2), but it doesn't work. it failed when I use ''FLASHBASH windows software''. I have used the the new version of pcb and and withot serial communication my pcb works. it seems that falshbash software on windows can not communicate with the pcb. when i try to do every funtion wich needs to communicate with pcb I get the failed message. would you please help me to solve this problem. regrds S.E.Alavi2004-09-16 2:44 AM
Both the hardware and software have been extensivly tested so double check your pcb and software versions.
If you have built the source then check #define SOFTUART has been commented out if using the 264. The s19 files on the website are built by default for the 264 (from v1.07). Regards sjoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
