2005-12-19 8:24 PM
2005-12-07 9:45 AM
Hi, I am using st7flite29 and ASM and I am getting phase inconsistency errors. I have read the manual but can not see how to locate where the error is occuring. There are about 25 errors but I suspect that once one error occurs then the rest will automatically follow. Any ideas?
Steve.2005-12-19 8:24 PM
Hard to help ! Can you attach some files ? You should be right a first error can cascade the other ones. Did you try to remove some parts of the code to find where the error is coming from. Best regards LaurentWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
