2003-12-01 6:21 PM
2003-11-26 11:04 PM
Hi
Is there anybody who can tell me where to obtain additional target connectors for the EMU3 emulator using QFP32 footprint. I need ti for the ST72F324K2T6 It's the small square (8 by 8 mm) PCB, which is soldered to the target board, to connect the emulator to the target. I would appreciate very much to have a make and part numer. Regards from rainy Denmark Kurt Müller Danfoss A/S2003-11-27 11:28 PM
Hi!
If you mean the socket and cover kit then you should contact Yamaichi I think(check in the probe user manual to see which manufacturer's parts have been used). In case you mean extra flex cables, the ST distributor should be able to help. Regards from tropical India, Dasg2003-12-01 2:43 AM
It is possible to order all the tools spare parts directly from ST.
Check the spare part list in order to find the order code corresponding to the items you are looking for in this web site at: http://www.stmcu.com/modules.php?name=mcu&file=accessory&FAM=152003-12-01 6:21 PM
Thank You to both of you
I found the sparepart on ST site It has ST order number AS-TQFP32. Actually i think it is an IRONWOOD ELECTRONICS, INC. device. www.ironwoodelectronics.com Their part number SF-QFE0325A-L-01. Nice day to all of you Kurt MüllerWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
