2021-12-13 3:21 AM
Hello ST-Community,
we are using the ECMF02-2HSMX6 in our USB3.0 application for ESD protection. Is it possible to change the D+ and D- lines? Internally, the part should be electrically the same, but it is not mentioned.
Thanks a lot
Holger
2021-12-13 4:45 AM
Hello Holger,
You're right, you can change the D+ and D- lines. Just be careful to connect pin 1 and pin 2 to connector, and pin 5 and pin 6 to USB 3.0 IC.
Best regards.
Fabrice.
