2005-04-21 10:15 PM
Data EEPROM & Flash memory protection
2005-04-17 4:55 AM
I like to use the ST7FLITE09 .This has 128 bytes of data EEPROM which i like to utilize fom In application programming .At the same time i like to have the security enabled - ie flash readout proection.My doubt is that when i configure the device for flash read out protection will i still be able to use the data EEPROM for read and write?2005-04-19 2:16 AM
Yes, You will be able to still write or read the EEPROM through In-application programming. The read-out protection is applicable for ICC mode. You can see the Flash programming refernce manual on the ST internet.
Hope this helps. bye venky2005-04-21 5:19 AM
Can you send the document number for the Flash programming manual ? Regards Prasanna2005-04-21 10:15 PM
hi,
find the attachment i downloaded from internet...see page.. ________________ Attachments : 1072800075.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Gf&d=%2Fa%2F0X0000000bWO%2FqW_tofKoCLG4gvzHNXclPy1857QNe1X7yYJPc.nFqAw&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
