jffs2 problem on M29W640DB
dipen_patel
Associate
Posted on April 21, 2005 at 14:04
2 REPLIES 2
dipen_patel
Associate
Posted on April 21, 2005 at 08:36
We are using M29W640DB bottom boot sector flash from ST Microelectronics for our MPC8248 based custom board.
We are getting following messages while booting kernel.
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x0020 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x22df instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x0008 instead
Further such events for this erase block will not be printed
JFFS2: Erase block at 0x00000000 is not formatted. It will be erased
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de0000: 0x0020 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de0004: 0x22df instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de000c: 0x0008 instead
JFFS2: Erase block at 0x00de0000 is not formatted. It will be erased
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
Kernel panic: VFS: Unable to mount root fs on 1f:00
Rebooting in 180 seconds..
Please see attachment for more information.
Can you please tell me what the problem is and how to solve it?
Regards,
Dipen Patel
________________
Attachments :
working_linux_flash1.TXT : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtqE&d=%2Fa%2F0X0000000aXe%2FoLAlOXSKSoY9kG9pCQ8JXTLc95IxiOtkcXi.MypAWPc&asPdf=false
marios
Associate II
Oops I don't think you're at the right forum.
