2009-10-02 8:35 AM
Cosmic problem
2011-05-17 6:04 AM
I'm trying to compile a cosmic project on STVD, but the followings errors occured : #error cpstm8 C:\Program Files\COSMIC\CXSTM8_16K\Hstm8\mods0.h:0 FlexLM Invalid host The command: ''cxstm8 +debug -pxp -no -l +mods0 -pp -i''C:\Program Files\COSMIC\CXSTM8_16K\Hstm8'' -clDebug\ -coDebug\ ''c:\program files\stmicroelectronics\stm8sfwlib\fwlib\library\src\stm8s_adc2.c'' '' has failed, the returned value is: 1 exit code=1. please help me, Matthieu2011-05-17 6:04 AM
Hi Matthieu,
You should add the local configuration to be able to access free cosmic license. Please follow these steps: Step1: Go to ''Start -> run'' and type ''regedit'' (Registry Editor is now opened) Step2: Go to ''HKEY_LOCAL_MACHINE ->SOFTWARE -> FLEXlm License Manager'' Step3: Add New Folder ''FLEXlm License Manager'' if not exist Step4: Add new string value name ''LM_LICENSE_FILE'' if it doesn't exist (floating menu then ''new -> String Value''). Step5: Add your free license path to ''LM_LICENSE_FILE'': For example C:\Program Files\COSMIC\CXSTM8_16K\License Regards, Mozra2011-05-17 6:04 AM
What are you implying by ''Step5: Add your free license path to ''LM_LICENSE_FILE'': '' What i have to do exactly. (Pardon me I'm a novice) Many thanks Matthieu2011-05-17 6:04 AM
mailto:stm8_16k@cosmic.fr
. Once you get the license, you copy it in the /lic subdirectory of the compiler and you should be able to compile. Did you do these steps already, or not yet? Regards, Luca (Cosmic)We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
