Others: hardware and software
STM8AL3189TCX out of regulation reset
Hi Team,We are using STM8AL3189TCX in our design and have some general querries for diagnostic report preparation(Specific to project)1) HOST MCU window Watchdog(TPS3850H33QDRCRQ1) If WDI pulse from HOST MCU fails this condition (Lower Boundary (tWDL...
Mlokesh by Associate
  • 737 Views
STPM10 replacement since it's NRND
Hi all. I'm about to start a project where we just measure the voltage and current of a single phase 220V 50Hz line. We need all the usual values (P, Q, S, cos phi, etc) using a CT and a standard transformer for the voltage. We also don't care that m...
Cocus by Associate
  • 917 Views
HCF4013 is can withstand 24V at 1Min test?
Hi sir,As per our application, we need to enable and disable the power supply IC enable pin. So we are using Flip flop based toggle function. so we are connect 12V rail directly (before voltage regulator).So as per ISO standard, our application shou...
VM.1 by Associate
  • 741 Views
LIN SC to ground
I am facing some issue.I have described some steps below,please go through it and let me how can I fix this issue through Software?Is there any flag need to clear/set or anything?I am using TJA1028 LIN transreceiver for this.Monitor LIN bus and +5VCo...
SSAYY.1 by Associate
  • 2040 Views
