2019-08-30 1:42 AM
when i am using 8 bit microcontrollers, i use compilers that have a lot of libraries to make my work in programming the micrcontroller very easy, e.g lcd library and a lot of libraries so the development of my code will be easy, in fact i am trying to move to 32 bit, so i would like to ask such these libraries is available in keil ? or i must build the libraries for interfacing other peripherals? can i find libraries for LCD, keypad and other things ?
thanks?
2019-09-03 4:00 PM
Just replace "Keil" with "Google" and yes, you can find there everything that exists under the sun.
Or you can find somebody who will create for you what you need.
-- pa
