Resolved! component eletronic
Please, i would like to know datasheet about this component. Someone could help me? because i need to change this component, and i can´t find it´s in my city.
Hi, Can anyone help please to identify what is this chip that hold the ST logo ? Here is the picture shows the chip. i searched a lot even on the digikey but i couldn't find anything.thanks
Good morning, I will try to be as concise as possible, I'm looking to change the location one of my GIT projects points to, I have a first software (STM32) where modifications have been made, and today I am looking to add a new project (STM32) to the...
I am using the ST discovery board, which has STM8S003K3. I have written a code that generates a PWM pulse when ADC senses that the input voltage is higher than a threshold value. I have tested this program with a Potentiometer and verified the wavefo...
Hello, I am writing some code to turn on an LED on my board through the IOExpander (STMPE811) but am facing some issues. I am able to read and write to I2C, and have done the following:written 1 to 0x10 (GPIO_SET_PIN) (Writing 1 to this bit causes th...
Posted on October 31, 2013 at 10:13 I am using STM8S 105C^Discovery with a Windows 8 Laptop. I tried to compile some example codes using Cosmic C Compiler with an Evaluation Key, but I got some errors. Here is the message I got ===================...
Previous I2C EEPROM chips had (eg) 3 address pins A2..A0, where you could hardware the I2C address. This allowed up to 8 devices on the same I2C bus in case you need more storage capacity.With the M24M01E this is no longer the case : the device can h...
Dear, I am looking for this component (diode) that I cannot identify to check its datasheet THANK YOU SO MUCHGREETINGS
I would like to examine the internal structure of the LQFP32 of the STM8AL3166. Are there any photos that show the internal structure, such as X-rays?
M95M02-DRMN6TPMay I ask if there are any cases that cannot be EEPROM programming that can be shared?We are unable to EEPROM programming,thank you
