Others: hardware and software
Doubt flash memory Nor retention
NOR flash memory chips behave the same as other types of flash memory. If I energize NOR flash once a year, will it prevent any data loss? The datasheet says retention 20 years. If I energize it after 19 years, will it prolong data retention?in my ca...
ÍStef.1 by Associate II
  • 7512 Views
VNLD5160
Hi at all.Can VNLD5160 work with a normal STM32 CPU with 3.3V logical levels?I don't find this information in datasheet...Thanks...
bestyeng by Associate II
  • 3067 Views
Regulator
Bonjour à tous voilà j'ai un transistor défectueux sur une carte electronique et je n'arrive pas à trouver son équivalent.Sur le transistor il y a inscrit GPLONC6OKD GKLKE V6 CHN 907je vous joint une photo du composant  Merci à tous cordialement 
position detecting with mpu6050
Hello, I want to control the position of my device with mpu6050. The logic is briefly as follows: I will mount my device somewhere, then with a command the device will save its current position. Afterwards, I want to know whether this device is in th...
scotzap by Associate II
  • 2192 Views
