Others: hardware and software
Resolved! Replacement for BMO055
Dear forumI need to update a board that uses BMO055 9 axis IMU and I need to know what is the preferred ST solution that best fit this obsoleted part.I need the 3 axis gyro + 3axis accelerometer + 3 axis magnetometerIf there is a single chip solution...
nachus001 by Associate II
  • 2887 Views
M41ST87W RTC Module Read problem
We use M41ST87W as RTC module. We set the stop bit (ST) to 0. We can also observe the frequency at the F32K output. We constantly read the Second register but we do not see any change. What could be the reason for this?
elehab by Associate
  • 1153 Views
Resolved! COREMP135 software
I purchase one M5STAck COREMP135, it noticed work for linux, but when I use the software, it can't handle user account , only use root login.Then I try build image by myself, the github support was 2-3 years ago.I see one training company - Bootlin s...
ST-LINK V2 windows 10
Hello ,  I have 5 ST-LINK/V2 and 5 products. Each programmer is connected to one product at a time. I am using Windows 7 and a USB hub. Everything works fine, but when I migrated to Windows 10, I encountered an unstable programming issue. I updated t...
Resolved! STM8S003F3 Datasheet pin description
I'm just starting to learn about MCUs and am reviewing the datasheet for the STM8S003F3. In the pin description table, I came across some symbols that I'm not quite sure about, such as bold X with underline (X), regular X (X), and dash (-). What do t...
zin10 by Associate II
  • 2297 Views
