Others: hardware and software
Problem with I2C on STM8L151
Posted on November 04, 2014 at 15:20 Hello, I tried distilling the peripheral library sample on i2c to make it simpler for my own use. However, strangely I cannot get pass a the send address part, and can't figure out why. Can someone give me so...
andy2 by Associate II
  • 1405 Views
STM8 support
Posted on November 05, 2014 at 23:46I am new-bee for STM8. I was using TI MSP430 before. how can i get some example codes to start getting zest of ST micro
abhishek by Associate
  • 842 Views
24-bit ADC interfacing with STM8S105
Posted on November 05, 2014 at 05:25Hello, I am interfacing a 24-bit ADC(HX711) with STM8S105 (STM8S discovery board). The intention is to read the weight(mv) from a loadcell(weight sensor) convert it via ADC to counts and display those counts via U...
Example of Manchester Decoding on stm8
Posted on October 31, 2014 at 19:22Hello,Do anybody has an example of manchester decoder for stm8 on C? As I understand, I should use a timer interrupts or an EXTI. Thank you.  #stm8 #manchester
tome by Associate II
  • 872 Views
STM8S003F3 I2c master-slave problem
Posted on October 29, 2014 at 13:28 I have two STM8 boards. One is master & other is slave. What master does is: send 4 bytes to slave & then read 4 bytes from slave. Problem: Sometimes the cycle work & many times code is stuck. I don'...
STM8/128 demo fw broken (UARTs)
Posted on December 21, 2013 at 16:23The STM8/128-EVAL demo firmware provided by ST is broken: It does not correctly enable the output pins for the TX lines. Thus you will never see anything on the USARTs in the adc demos that are supposed to use the...
