Others: hardware and software
USART1 Receive Problem with STM32L072CZ
Posted on November 23, 2017 at 21:34Hi,I'm trying to read via USART1 the bytes generated by the GNSS module.I'm developing on the discovery kit B-L072Z-LRWAN1 board (Discovery kit LoRa), where the TX and RX pins of the GNSS module are connected resp...
ADC conversion time
Posted on December 01, 2017 at 11:36Hi,I nedd to execute an adc conversion in STM8S003. I read that te conversion time is about 2.3us, but I see that the time in my project is about 25us. Configuration of  CLK_Config(void){ /* Initialization of the ...
sav gas by Associate II
  • 1046 Views
STM8AF Bootloader UART write memory
Posted on December 01, 2017 at 03:24I'm currently programming a bootloader for my project. I work on a STM8AF board and I have a problem with the write memory command.I follow each instruction in the UM0560 user manual. My problem appears at the end...
Getting an delay by timer interruption
Posted on November 13, 2017 at 17:44Hello Everyone,I am working on the STM8AL3166 and try to handle a timer interrupt. My need is to wait 500ms and then check again a value (not pooling)How/Where do I write the program when the interrupt occurs? Whe...
david.ye by Associate II
  • 5435 Views
  • 11 replies
STNRGPF01 Programming
Posted on November 29, 2017 at 15:11STNRGPF01 ProgrammingTo program the http://www.st.com/content/st_com/en/products/power-management/ac-dc-converters/pfc-controllers/stnrgpf01.html devices when working with https://my.st.com/analogsimulator/flex_ap...
0690X0000060917QAA.png 0690X000006090xQAA.png 0690X00000608uRQAQ.png 0690X0000060912QAA.png
ST62T25C6 issue
Posted on November 29, 2017 at 05:52hHai every body,iam using ST62T25C6 in a control board used for opening and closing of a valve. I copied the program from old IC to New one, when i insert new one the program is not enabling and when i insert old ...
STM8S001J3 SWIM pin setting
Posted on November 28, 2017 at 10:01Hi.I have a problem using STM8S001J3.The program can not be downloaded because the SWIM pin is set to output.Is there a way to revert the settings?I am using STVD and IAR for program development.#stm8 #stm8s
