how stlinkv2 reset the mcu
I connect the stlinkv2 to stm8. then the reset button on board not work, Is there a way to reset the stm8 using stlinkv2?. thanks
I am a starter for stm8 mcus I installed STVD and COSMİC C Compiler. at first step -i can not save my project-i can not uncomment my mcu in stm8s.h header fileI get an error message "Access to C:Users\R&P\Desktop\first\inc\stms.h"Access to C:Users\R...
1N825A T54LS74AD2We will need their Status (Active, Obsolescent, Obsolete), their Sustainability and their Compliance with regulations (REACH, RoHS, SRI, CMR). Would it possible to send you our full request by mail and/or to a specific contact?
Hello, We are using M24512 EEPROM in our water meter pulse counting device. Our device is battery operated pulse counter from a mechanical meter using a reed switch. Pulse Count Saving mechanism:When reed switch trigger by mechanical meter, our ultra...
char shiftdata=8;shiftdata=_asm("rlc a",shiftdata).I am trying to rotate left through carry value 8, expecting output of 16. When I debug the code, I am getting shiftdata value as zero, instead of 16.Can you help me with this?
I am using STVD and Cosmic Compiler and after add some #include files, the "Control + space" stop working. It doesn´t find the SPL (StdPeriph_Lib) function anymore. Hope anyone to solve this problem. Thanks
hi,I installed STVD and Cosmic C mopiler. I downloaded SPL from ST website.created first project.installed SPL soruce files and include files.I will uncomment line #define STM8S003 (line49) but compiler gives error."Please select first the target ST...
I am trying to measure the frequency and duty cycle of a PWM input on TIM5 channel 1. My frequency is being measured correctly but the duty cycle is not. GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT); //PWM inputI am using the 16MHz HSI clock ...
