2010-09-08 8:11 AM
AWU - what's wrong ?
2011-05-17 6:10 AM
there is an option bit CKAWUSEL (see datasheet) to select awu clock source.
brazov
2011-05-17 6:10 AM
2011-05-17 6:10 AM
Ok, just read in the AWU interrupt routine the AWU_CSR register to clear the AWU interrupt. After HALT instruction, AWU generates an interrupt after a certain time, according value you set in AWU configuration registers, then exting from HALT micro jumps on AWU interrupt routine. Try it will work.
brazov2
