2017-04-03 3:56 AM
Hi good morning,
I'm developing an apple watch health care application. After a search i discover an ST microelectronics accelerometer sensor mounted on a system on a chip internally.
Here there is the sensor data sheet:
I want to know one only thing: Which is the full scale range ? I read the data sheet but i've found 4 differents range for range on axys (2G, 4G, 8G, 16G)!
I'm not very expert with data sheet reading, someone can help me ?
Thanks in advance, have a good lunch!
#applewatchaccelerometer #fullscalerange #accelerometer2017-04-04 9:06 AM
I don't have any experience with applications for Apple Watch, but the range can be changed dynamically during sensor operation by operation system. I assume it is transparent for the application and the OS should provide directly acceleration value in g or m/s2 to your application.
2017-04-07 5:17 AM
Yeah I know the Sensor is programmable, but the built in sensor inside the Apple Watch is not programmable from external, so it is set to a specific range.
I don't know which is the range maybe I should to write to support center to know it?
Thank you for reply
