2019-11-08 4:04 AM
i use the lis2dh12 accelerometer and lis3mdl magnetometer for making tilt compensated compass. i read datasheet and application but i have below list of confusion
q 1] which type of data of accelerometer is used for calulate roll and pitch either raw data or converted G data?
q 1.1] which equation is used to convert raw accelerometer data to G value ? with example value.
q 2] which data i need to put inside accelerometer 3 x 3 misalignment matrix ? this question is related to accelerometer calibration.
q 2.1] is it raw data or converted g data?
q 3] explain misalignment matrix (between magnetic field and sensor frame axes) of magnetometer ? this question is related to magnetometer calibration.?
q 4] once the program is done is the tilt and direction with degree is that affected by different place like india to america?
2019-11-08 8:22 AM
Hi @Mpraj.19 , trying to answer to your questions here below. Please refer to UM2225 for further information.
>> converted G data are used in the eCompass algorithm
>> depending on the FS set, one of this conversion formulas is used (ref. github drivers)
float lis2dh12_from_fs2_hr_to_mg(int16_t lsb)
return ( (float)lsb / 16.0f ) * 1.0f;
float lis2dh12_from_fs4_hr_to_mg(int16_t lsb)
return ( (float)lsb / 16.0f ) * 2.0f;
float lis2dh12_from_fs8_hr_to_mg(int16_t lsb)
return ( (float)lsb / 16.0f ) * 4.0f;
float lis2dh12_from_fs16_hr_to_mg(int16_t lsb)
return ( (float)lsb / 16.0f ) * 12.0f;
}q 2] which data i need to put inside accelerometer 3 x 3 misalignment matrix ? this question is related to accelerometer calibration.
>> always in g
I believe you should take inspiration from MotionEC library of X-Cube-MEMS function pack.
2019-11-08 8:22 AM
>> always in g
