2021-01-08 8:15 AM
When reading the temperature from a LSM9DS1, what's the unit that is used ? Cº ?
2021-01-11 7:03 AM
Hi @PRebo.1 ,
The measurement unit is °C, but you have to convert the 16bit value into °C according to the 16 LSB/°C, as described in the datasheet, p. 14.
I suggest you to check also the C drivers on Github for the LSM9DS1, in particular the lsm9ds1_reg.c file and the LSB-to-degC conversion formula:
float_t lsm9ds1_from_lsb_to_celsius(int16_t lsb)
return (((float_t)lsb / 16.0f) + 25.0f);
}Please let me know if this answers your question.
-Eleon
