2024-01-10 10:50 PM
Hi all,
I am using ST tile box pro and logging IMU orientation data for my test. I did place that module in a robotic arm and then calibrate the accel sensor. I observed 20 degree drift in the heading value after the calibration .
Before calibration almost 0. I did ensure the origin. Kindly explain what's happening after the calibration. Thank you.
2024-01-25 1:05 AM
Hello @DavidThomas I'm sorry I'm on business trip I will come back to you next week.
2024-01-29 9:46 AM
Hello @DavidThomas,
Recommended sampling rate for MotionFX is 100Hz.
Atime represents weighting on Kalman filter’s measurement noise matrix, increasing this will reduce the trust on the accelerometer sensor measurements.
Atime = 100 was just an example, you can try different values to fine tune the algorithm for your use case.
2024-01-30 9:06 AM
Thank you so much @Miroslav BATEK .
