Sensor TileBox
Smithson
Senior
We had three Sensor TileBox units. In an interesting morning of work, I got the one I have in the USA running, in the hope that the people in the UK who have them could use them.
I got it running, during the reading to get it running, I found a note in one of the PDF files that said the CSV files would be padded to the highest ODR.  First time I had actually seen that other than in a ST reply.
The TileBox recorded nicely once I worked out the boot key, which is one of three buttons and the PDF does not show it that I could find.  I knew I had seen it once, but I could not find it.  I enjoy playing with the combinations
The CLI_Example program worked nicely.  The sample files json files were challenging.
Following the instructions, it proved difficult, I could not do transfer the data to CSV, Unicleo GUI did not help as suggested.
Anyway we are throwing them away, but it was some fun.
Once you establish a standard method it is better to stick to the standard, so changing acquistioninfo.json to acquistion_info.json might seem like a good step, it is not once the first is being used.
Anyway, London was fun.
0 REPLIES 0
