Multiple STHS34PF80 IR sensors nearby each other.
aziubin
Associate II
Can several STHS34PF80 IR sensors be used simultaneously, when placed not far from each other, say on the same PCB? If STHS34PF80 infrared sensors are completely passive devices, there should not be any limitations of the distance between them, even if their fields of view are intersecting, right?
1 ACCEPTED SOLUTION
Accepted Solutions
Peter BENSCH
Correct, the STHS34PF80 are purely passive components and can be positioned directly next to each other without any problems and without any mutual interference.
Good luck!
/Peter
1 REPLY 1
Peter BENSCH
Good luck!
/Peter
