2021-03-18 3:02 AM
We found variation in measurement reading below 4 cm. Kindly confirm whether it is possible to measure below 4cm using VL53L0X
2021-03-25 3:57 AM
Hi @YGude.1 ,
As far as I can see from Arduino community, they say:
"The datasheet does not specify a minimum range, but in our experience, the effective limit is about 3 cm."
I believe this is a limitation in the application more than in the device itself, but measures below this distance might be more tricky to deal with.
-Eleon
