2022-06-10 8:58 AM
I am looking at the LSM6DSM datasheet for power draws. Here is an example
Does the current required by the LSM6DSM accelerometer change if VDD is toward the upper end, say, 3.3 V? Should I expect lower, or higher, power draws? Basically fill out the following:
Thanks in advance!
2022-06-17 8:49 AM
Hi @CMehr.1 ,
please consider that the main increase in power consumption is given by a change in the ODR frequency.
A change in Vdd from 1.8V to 3.3V qill increase the accelerometer power consumption by about 2 / 3 uA.
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
-Eleon
2022-06-17 8:49 AM
Hi @CMehr.1 ,
-Eleon
