2016-10-13 6:47 AM
Hi
I have 2 LPS25HB pressure sensors. I moved them from exact the same level to another level. The readings from both sensors are different. The start points are different and the slope of the value change is also different! However, i just programmed to read the value out without editing any reference or offset, or differential setting. Can i correct the results by editing some registers, if so which registors?Thanks RuiWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
