2016-11-03 9:34 AM
Hi all,
i use an accelerometer LISDH12, and it have a very high consumption (400 uA).I have this configuration;Someone have a suggestion about this problem?
Thanks,Anna #high-consumption2016-11-04 3:07 AM
I suppose the sensor is LIS2DH12.
You didn’t specify if the sensor is running and what is the ODR, it has an influence on current consumption.
Also connecting SDO/SA0 pint to ground will induce
mailto:~130uA@3.3V
current. So if possible connect the SDO/SA0 pin to Vcc and use the second I2C address.
Best regards
Miroslav
2016-11-09 12:57 AM
2016-11-11 2:31 AM
Can you please share your schematic?
Best regards
Miroslav
