2013-12-12 9:48 AM
hi,
I use LIS3DSH and a problem appear sometime at init, in fact we catch false value from chip (offset error on x axis). Only offset is not correct (same offset value in case of pb). SPI bus reading is correct , value come from chip. Do you have any reason for that , may we use any control to indentify error ? Thnaks in advance, Regard,2014-01-10 5:09 AM
Hello Thierry,
What is the value that you are reading for the initial offset value? If possible, could you please attach the section where you setup CTRL_REG2 (21h) and an image showing the measured values? Thank you, Thiago ReisWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
