2013-04-01 7:19 AM
Hello.
I use LIS3DH accelerometer with 4-wire SPI interface.I attached schematic of accelerometer connection (AccelSch.pdf).ACL_VDDIO = 3,3 VACL_VDD = 3,3 VOther ACL signals connect to microcontroller pins.R9A=R9B=R9C=R9D = 100 Ohm.When I configured accelerometer to work in 4-wire mode I saw that accelerometer send data on SDI pin 6. (SPI_Data_Transfer_4wires_Mode_Img1.jpg and SPI_Data_Transfer_4wires_Mode_Img2.jpg).Yellow signal - clock (SCL pin 4).Green signal - SDI pin 6 on net ACL_SDA/SDI/SDIO.When I configured accelerometer to work in 3-wire mode I saw that amplitude of signal on SDI pin 6 increased (SPI_Data_Transfer_3wires_Mode.jpg).Why accelerometer send data in 4-wire mode?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
