2021-07-27 4:12 AM
Teraterm Issue
2021-07-28 5:08 AM
Hi, the FP-AI-SENSING1 is designed for BLE communication; if you are interested in streaming data via VCOM with the SensorTile.box you should use for example the FP-SNS-STBOX1, where the DataLogExtended should stream data on USB.
https://www.st.com/en/embedded-software/fp-sns-stbox1.html
Tom
2021-07-28 5:08 AM
Tom
2021-07-28 7:41 AM
@Community member Thanks for your immediate response.. I will download and validate
2021-11-12 10:02 AM
is there also a way or isntructions for how to get access to the usb serial data without the incleo-gui? ideally to a linux system?
2021-11-17 6:24 AM
@JGies.1- How about using USB to UART Convertor boards available in FTDI
2021-11-17 6:25 AM
@JGies.1 How about using USB to UART Convertor boards available in FTDI. It is working fine.
