2024-01-17 11:53 PM
After soldering process, IMU sensor and magnetometer need to do calibration after power on, such as flip axis, 8 shaped pattern, or real-time calibration.
For ST sensor such as LSM6DSV and LIS2MDL, I want to know how to confirm whether sensor has been calibrated?Is there any levels to judge the status?
2024-01-18 11:37 PM
Hi @Yansu ,
I confirm you that the sensors are already calibrated by factory.
However, for some applications, for example after soldering, it could be suggested to subtract residual offset (for accelerometer) and ZRL (for gyro). To do so, acquire some samples for each axis and calculate the average. Then substract this value to the acquisitions.
2024-01-19 2:07 AM
Thank you for your reply.
Yes, I mean calibration after soldering. Is there API or register to get this calibration status?
2024-01-19 6:58 AM
Hi @Yansu ,
You could look at our MotionFX library, here the user manual. You can find also some examples on github.
Let me know if this helps.
2025-08-18 9:36 PM
May I know whether we can ready the factory calibration values?
We are using LSM6DSV16B
We try to read the following register, but seem all returning zero.
