2013-10-23 2:48 AM
As Interrupt sources, what means the ''X/Y/Z High Event'' or ''... LOW Event'' in the datasheet?
Are there defined trigger values for these events, and are they changeable in some registers? #h3lis331dl #accelerometer #application2013-11-18 4:39 AM
Hello Mai,
This section of the interrupts means that the interrupt will occurr either when the acceleration value is higher or lower than the determined threshold value. Please check on page 30 of the attached datasheet for the configuaration of the interrupt registers and on page 32 for the thresholds setup. Please let me know if this helps with your question, Thank you, Thiago ________________ Attachments : H3LIS331DL.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzLP&d=%2Fa%2F0X0000000bKH%2FV46QYBE_NCTUfl2Bg7EaHWgS1H8cvyQQatVt8QokIro&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
