Got data from LSM6DS0. Next step.
Posted on August 09, 2016 at 19:00I’d like to understand some basics, how to work with the device. I read the data from the chip and see it on terminal but I don’t understand how to practically use the data. Also when I use ACC data and when I use G...
LSM6DS3 Accel/Gyro ADC Resolution?
Posted on March 29, 2016 at 08:06Interested in purchasing the LSM6DS3 device. Studied the datasheet carefully, and there is no information on ADC resolution for the accelerometer and gyro. This is odd considering this is a key spec for any prospecti...
LSM6DS3 cross axis sensitivity
Posted on April 14, 2016 at 01:24Does anyone have information on the LAM6DS3 cross axis sensitivity? I cannot find this on the data sheet, when this is supposed to be a standard spec on other similar products. I contacted online support and they ask...
kh by Associate
  • 1098 Views
LSM6DS3 Resonance frequency
Posted on April 14, 2016 at 09:52Hi everybody, I'm using LSM6DS3 and I need to know its resonance frequency. In the datasheet this information is not present. Thanks in advance #lsm6ds3-resonance
massimo2 by Associate II
  • 1030 Views
IIS2DH Temperature sensor data
Posted on August 07, 2016 at 13:03Hello,1.according to section 2.11 Temperature sensor :should i read both OUT_TEMP_L (0Ch) & OUT_TEMP_H (0Dh) ?the data is stored only in OUT_TEMP_H (0Dh) ?2.the data i get using OUT_TEMP_H (0Dh) is too low (10C-13C)...
amirma by Associate
  • 1131 Views
hts221 returns 0xAE
Posted on August 04, 2016 at 10:48HTS221 after read all humidity registers final value always 29.0% and not changed in time. All data register contain 0xAE values. ST firmware driver for HTS221 also returned 29.0% and 0xAE registers values. Connecti...
LSM9DS0 magnetometer
Posted on August 04, 2016 at 11:54Hi,I'm working on lsm9ds0 and spi with a stm32f4. The accelerometer and gyroscope work successfully on my device but since a few days, the magnetometer seems to get random values. For test, gyroscope is in power dow...
theo2 by Associate
  • 797 Views
LIS331HH power consumption
Posted on July 27, 2016 at 07:20Hi,I try to get power consumption about 10 uA using LIS331HH in low-power mode (power supply voltage 3V). But I've got 23 uA average power consumption in low-power mode (0.5 Hz data rate).Working cycle: sleep (power c...
