LPS25HB single point calibration after soldering
Posted on August 16, 2016 at 19:32I am trying to produce 6 matched sensors. I have soldered them and I can query them via I2C, but their values are significantly off true air pressure. I know I'm supposed to use the RPDS_L and RPDS_H registers, but ...
Problem linking in API VL53L0x
Posted on August 15, 2016 at 17:56 I am trying to use the API for VL53L0x proximity sensor over one smt32F4Discovery developement board and I am not able to do it. The steps that I am doing are the following: In a Keil project that it compiles ...
LSM303D temperature sensor
Posted on June 13, 2016 at 14:41I could find the resolution of this sensor, 8 LSBs/DegC, but I couldn't find any information about how the absolute temperature is specified. Does anyone have more information about it? #ecompass #lsm303d #temperat...
kurt23 by Associate
  • 1003 Views
Reliability data for IIS2DH
Posted on August 10, 2016 at 15:35Is there any FIT and/or reliability data available for the IIS2DH accelerometer?
latise by Associate
  • 923 Views
LSM303D temperature format
Posted on July 04, 2014 at 15:19Hello,I got good results reading accelerometer data but the temperature register is about 36 (decimal), the datasheet mentions 8LSB/°C, 36/8 = 4.5°C, this is quite cold ;) Room temp is 24°C, the other sensors locat...
tarzan2 by Senior
  • 1209 Views
LIS3DSH Temperature Output
Posted on July 20, 2016 at 15:35The LIS3DSH was implemented into one of our systems and currently we are having an issue with the Temperature readings across multiple units in the same environment vary from one another up to 15ºC. Is there a way to ...
LSM9DS1 Frequency Response
Posted on July 08, 2016 at 14:55Hi, We are looking for and 9 DOF sensor which should have good frequency response. I go through datasheet but was not able to fetch the frequency response details. Can you tell me the frequency responce of Part♯ LSM9D...
bimal by Associate
  • 1106 Views
Audio Playback and Record project using CooCox IdE
Posted on August 10, 2016 at 16:45I have downloaded STM32F4-Discovery_FW_V1.1.0 firmware package and want to use the example of Audio Playback and Record on STM32F411.I am facing a lot of problems in building the project itself such as C:\CooCox\CoI...
jainpl15 by Associate
  • 971 Views
LSM9DS1 Gyroscope Sensitivity:
Posted on August 10, 2016 at 14:17Hi, We are looking for the product&sharpLSM9DS1, where it mentions sensitivity of 8.75mdps/LSB @ �250�/sec range. I would like to know the sensitivity at �125�/sec Range? Is it half of 8.75mdps? Is the range of �12...
bimal by Associate
  • 947 Views
