LIS3MDL calibration
Posted on July 14, 2017 at 07:24The magnetometer on my device has different scale and offset on its axes.This is because of influence of hard iron on the board. So, it needs to be calibrated. I've read https://my.st.com/resource/en/design_tip/dm0028...
sdianoff by Associate II
  • 3172 Views
AppsNote for STM32CubeFunctionPack_MOTENV1
Posted on July 13, 2017 at 23:03I just downloaded the new STM32CubeFunctionPack_MOTENV1_V3.0.0 and going through what motion sensor library could do all at once.As I walk through the code in MEMSCallback(), all the W2ST_CHECK_HW_FEATURE checking is ...
Why will my linear sensors not normalize?
Posted on July 09, 2017 at 14:40I posted in another forum but a fellow user suggested I post here.https://community.st.com/thread/41907-why-does-my-linear-sensor-array-not-scalenormalize?sr=inbox&ru=17270null
LIS2DH12 temperature and acceleration always read the same
Posted on June 01, 2017 at 15:39I've got my LIS2DH12 configured as follows:TEMP_CFG_REGTEMP_EN0x11CTRL_REG1ODR1LPEN0ZEN1YEN1XEN1CTRL_REG2HPM0HPCF0FDS0HPCLICK0HP_IA10HP_IA20CTRL_REG3I1_CLICK0I1_IA10I1_IA20I1_ZYXDA0I1_WTM1I1_OVERRUN0CTRL_REG4BDU1BLE0F...
STEVAL-MKI155V2 pin map
Posted on July 05, 2017 at 14:43STEVAL-MKI155V2 coupon board,cannot find exact pin number.On silk on the board, and no layout file on st site.And on en.DM0006727d.pdf, bottom view image seems to be mirrored.Please let me know where  I can  find the ...
isjeon by Associate II
  • 706 Views
Resolved! LPS25HB not working with X-NUCLEO-IKS01A1 and Arduino uno
Posted on June 29, 2017 at 16:53Hi,I'm using X-NUCLEO-IKS01A1 with arduino uno,I'm getting the output for HTS221 with the codehttps://github.com/ControlEverythingCommunity/HTS221/blob/master/C/HTS221.c  ,the connections seem to be correct but when I...
LPS25HB not giving correct output in Atmel SAM Gseries
Posted on July 04, 2017 at 15:39Hi,I'm using X-NUCLEO-IKS01A1 board for integrating the pressure sensor in my Atmel board SAM G55 series.I'm using the reference code of https://github.com/ControlEverythingCommunity/LPS25HB/blob/master/C/LPS25HB.c .I...
LIS3DH Z output noisy
Posted on June 05, 2017 at 11:40I am trying to measure a machine's vibration using LIS3DH sensor. I set the LIS3DH in low power mode and 5.376 kHz sampling frequency which outputs 8 bit output. I use spi to get the data from the sensor. I changed th...
