red light freezed in STEVAL-MKSBOX1V1
i connected sensortile.box to charger and simultaneously i was uploading the app in expert mode usimg inputsTemp SensorHumidity Sensor Pressure SensorMicrophoneand function as FFTand saving output to sd card it got freexed at red light and app was no...
Pgarg.11 by Associate II
  • 1974 Views
[LSM303AGR] The compass does not work.
The LSM303AGR chip is used in Android device. I use STMems_Android_Sensor_HAL_Input sensor HAL from https://www.st.com/content/st_com/en/products/embedded-software/mems-and-sensors-software/drivers-for-mems/androidhalinput.html.The magnetometer works...
Weird Range reading delay with VL53L1X
Hello,I am looking to scan a 2D surface with the ROI feature of the VL53L1X. I have been following the doc UM2555 and using the Polulu ST API but I can't get it working properly. The wall is at 1.6m and the object at 48 cm. The precision is not the i...
PChat.1 by Associate II
  • 2298 Views
IIS2DH axis Y not working
Hello,i use iis2dh (STEVAL-MKI168V1) on Arduino Due through spi.unfortunately, the y axis does not respond (I tried 3 development boards!).if instead use STEVAL-MKI135V1 board the same firmware works.could someone help me?best regards,Francesco
FItal by Associate II
  • 2443 Views
