Hi, I plan to use a VL53L1x sensor pair to implement a very low-bandwith local communication as a side duty of ranging. For this purpose I need to be able to precisely control laser emission of VCSEL. Is is possible to timing VCSEL laser emission by...
Is there a way to use the VL53L1X sensor to be dust and water resistant? I watched the Calibration-Free Dirty Environment Cover Glass Solution video and does this protective glass layer also provide water resistance?
Please direct me to the document that specifies the orientation of the SPAD to the package. My application requires a short but wide FOV.
The LSM6DSL, LSM6DSR have a sensor hub and I'd like to connect the VL53L1X Time of flight sensor to the sensor hub and have the IMU automatically read information from the VL53L1X.From reading the sensor hub documentation in the datasheets as well as...
We wish to use the sensor in a freezer behind a protective plastic cover. We expect some frost and dirt to be an issue on the outside of the glass. We are considering an optically clear adhesive between the glass and the VL53L1X to prevent frost and ...
Will the VL53L0X measure the distance to the surface of clear water in a container if pointed down into the water perpendicular to water surface?
I have three accelerometers and the circuit is designed according to the datasheet. I have collected the data of three kinds of accelerometers with the vibration test-bed. The sampling frequency of the accelerometers is all set to 800 Hz, placed hori...
Hi, I am developing a device that uses the accelerometer/magnetometer LSM303AGR.The problem is that datasheet doesn´t comment about temperature sensibility (For example: Sensitivity = 16 LSB/°C in lis2dtw12)Could anyone give me an equation to convert...
I am trying to use an acoustic scene classification from the sensing1 function pack (https://www.st.com/en/embedded-software/fp-ai-sensing1.html) that the stm32 provided for the sensortile.box. I have a difficulty integrating its sample python code m...
