VL53L1X Sensor VL53L0X_StaticInit() failing
While implementing the middleware for vl53l0x I am facing the following problem. Can you please let me know what mistake am I making “please see the commands in bold�?       tofDev->I2cDevAddr = VL53L0X_I2C_ADDR //0x52;       tofDev->comms_type = I2...
Kpodu.1 by Associate II
  • 1147 Views
How to compensate for asymmetric sensor array response?
I have an array of three VL53L0X sensors, mounted at -20, 0 and +20 degrees with respect to each other. The idea is to use the differential between the distances measured by the three sensors to determine the orientation of my autonomous wall-follow...
FPayn.1 by Associate III
  • 1923 Views
How to implement callbacks to my i2c code for the VL53L3CX
Hi,I am implementing the VL53L3CX in a custom design and am trying to get the API working. The documentation says that there is one sample included in the API that shows how to call it. It is not present in the supplied API download (VL53L3CX_BareDri...
Kevyk by Associate
  • 1060 Views
Connect LSM303AGR Interrupt Pins, really necessary?
Hi.Excuse me if this query seems very silly, I am designing a schematic and it will take the integrated LSM303AGR because I need to read accelerometer and magnetometer data by I2C.What happens if I leave the accelerometer interrupt pins (INT_1_XL and...
Gustbel by Associate
  • 1758 Views
IIS328DQ I2C Setup
IIS328DQ CS, SCL, SDA, and SA0 pins are having internal active pull up. If I were to use I2C communication, do I need to connect CS pin to high? Since it is already had internal active pull up, I don't think that we still need it....please confirm.
KTeng.1 by Associate II
  • 1111 Views
IIS328DQ PCB Design Guidelines Unclear
Not quite clear about the statement " "Pin 1 Indicator" unconnected during soldering " as mentioned in the datasheet. Can someone elaborate on this?In the Recommended Land and Soldermask design, the statement "PCB THERMAL PAD NOT TO BE DESIGNED ON P...
  • 925 Views
