Is there any SAI PDM example for STM32MP1?
I'm looking for device tree configuration to acquire 4/6 PDM microphones resulting in an ALSA tdm stream. It's mentioned in the official documentation here(https://www.st.com/content/ccc/resource/training/technical/product_training/group0/30/7d/ca/21...
ARicc.1 by Associate II
  • 3919 Views
Lsm6ds3: I'm working on Fifo functionality of Lsm6ds3 for z-axis but when i retrieve values I'm getting higher g values of 2g at steady state. Can somebody explain why such higher values are generated.
I'm using FIFO in continuous mode and when i read from LSM6DS3_ACC_GYRO_FIFO_DATA_OUT_H register most of the times I'm getting constant value of 0x0F from this register at steady state. The values generated at steady state are 2g always.
RK.6 by Associate
  • 1299 Views
About accelerometer LIS3DH
I am considering an accelerometer.The accelerometer is experimenting with LIS3DH.I want to mount an acceleration sensor on a surgical light and detect the movement of the lighting part of the surgical light.I want to issue an INT interrupt when the l...
OHide.1 by Associate
  • 1914 Views
Hi, I test LPS33HW
What can happens with parameters of this sensor if we place it into a water of swimming pools ( with any concentration of chlorine and other salts) and it stays there months and years ??? Do it need any maintenance or replacement after a period of an...
RPesi.1 by Associate
  • 1248 Views
lsm6dsl int1
Dear Sir.I work with LSM6DSL with SPI bus ,The wiring are OK , I can read the register who_am_i.I can't makie the INT1 to work.Attached a codeint32_t lsm6dsl_orienation_config(void){  int32_t ret = true;  unsigned char z;//  lsm6dsl_gy_full_scale_se...
