what format is the return buffer of the PDM2PCM function
Hello,I am trying to understand how the PDM_Filter() function works. If I am using 48Khz with a decimation factor of 64 and a output samples = 16If I call the function like this...uint16_t MidBuffer[16]; uint16_t pdmRxBuf[128];PDM_Filter(&pdmRxBuf[0...
kcire L. by Associate III
  • 1242 Views
Resolved! LIS3MDL Longevity
Hi,May I know about LIS3MDL longevity?I checked here (https://www.st.com/content/st_com/en/about/quality-and-reliability/product-longevity.html#10-year-longevity&section=FM89-10-year) but not found.Thanks,Rezan
MResa.1 by Associate II
  • 2764 Views
Resolved! Can't operate MKI207v1 with MKI109v3.
I am trying to run MKI207V1 with MKI109V3, it does not work because MKI207V1 does not appear in the list of devices.I know I have no problem with MKI109V3 because I can run MKI159V1.I would not complain, but appears on the company website that MKI207...
OBaha.1 by Associate
  • 1169 Views
Hi, I am using the LSM6DSOX mems and the ST Unico software to build machine learning models to be run on its MLC. Once, I generate the .ucf file is there a way to decode/backtrack it to the configurations that were set to create it?
Once I have a .ucf file for the model, I just want to know if we can backtrack to the configs used. This would help in version control and maintenance of the MLC code.
HErla.1 by Associate
  • 1624 Views
