TESEO-LIV3F GPS interface with QN9080
Hi ST support team,Am present working on TESEO-LIV3F GPS interface, these device is used on my customized board for GPS co-ordinates latitude and longitude, but here am facing some issues mentioned below.1.My GPS co-ordinates longitude and latitude v...
Snagu.11 by Associate II
  • 1442 Views
Resolved! No Update form lis3mdl time to time
Hello,Our board is streaming accelerometer, gyrometer(lsm6dsox) and magnetometer(lis3mdl).It sleep and wake-up depends on accelerometer threshold.Usually data is streamed out well.But time to time, data is not updated from magetometer after wake up....
JPARK.2 by Associate II
  • 1578 Views
MP34DT05 Sensor PDM output issue
Hello, I am trying to interface MP34DT05 - MEMS Audio sensor in mono configuration to read audio samples from sensor. Basic working of PDM Audio sensor states that, the analog signal will be sampled at PDM CLK frequency and outputted as pulse modul...
Resolved! Eleon, help, again. Latest firmware for Sensor.box...
Hello, Eleon. My app tells be that v3.47 firmware for the sensor.box is available. The Android app tries to download and install but I never could get that to work properly. Can you post the new v3.47 firmware please.Thanks,Tony
TJM by Senior II
  • 2910 Views
Offset cancellation procedure with LSM303AGR.
I can't figure out the right implementation of LSM303AGR offset cancellation with single measurement mode. If I set to 1 OFF_CANC an OFF_CANC_ONE_SHOT in CFG_REG_B_M, then I have to do 2 readings and apply the Offset cancellation formula? The SET / R...
LCenn.1 by Associate
  • 2292 Views
Not getting gyro value accurate
LSM6DOXTR , I m reading this sensor by configuring 0x10 and 0x11 modules to 0x60 and 0x60 as show in user guide by ST but  the values I get of accelerometer are correct while gyro value jump to 0 to 255 as I am only reading MSB. LSB is changing rapid...
DBish.1 by Associate II
  • 1883 Views
