Resolved! DEAD-RECKONING MODULES (GPS + IMU(sensor fusion))
Hi Team,Am presently looking for GPS + IMU (sensor fusion) module in STM, what is the best GPS + IMU module and why ? Is sensor fusion algorithm is used in IMU module, if not which algorithm is used in that module, please suggest me best Dead reckoni...
Snagu.11 by Associate II
  • 4918 Views
Can offset registers on LIS2MDL compensate strong magnetic field?
Hi, I'm working on a prototype device. It is very compact, battery powered and has a motor inside. I want to know if the offset can be set (during production) to compensate a very strong magnetic field and still be able to detect earth magnetic fi...
MHo by Associate II
  • 3129 Views
  • 10 replies
Amplitude from FFT Data
Hi,I am using IIS3DWB and i am applying FFT on converted mg data. Now how can i find amplitude from FFT data?
HPate.7 by Associate II
  • 1556 Views
Resolved! I have Sensortile.box (STEVAL - MKSBOX1V1) and Sensortile Kit (STELVAL -STLKT01V1). I need to check onboard LED port, UART port, BLE baord and sensor port where shall I find the details.
1) Port Details of this BSP - LED, BT, Sensors GPIO configuration details. In the source how shall I find it. Example if I download en.stsw-stlkt01, where shall I find the pin configuration details2) Similar to UART and Sensors and BT Step by step g...
why the lsm6dso step count is not accurate for slow waking?
I am using the lsm6dso accelerometer I am setting : Full Scale= 2g, ODR=12.5Hz for this setting fast waking, step count is not accurate ( 4 steps out of 10 steps)after that, I changed the setting: Full Scale=2g, ODR= 26Hz for this slow w...
Jm.9 by Associate II
  • 997 Views
