Hello!Our application uses accelerometer in three modes:power downmotion detectiontilt angle monitoringHere is power down mode configuration:lis2dw12_data_rate_set(&handle.acc_dev, LIS2DW12_XL_ODR_OFF);Motion detection configuration:accel_soft_reset(...
I wonder if embrio can help me solve my problem. I have little programming experience. I'm trying to build a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display. I want to draw the data as close ...
According to the data brief STSW-STLKT01 Embedded software samples for SensorTile (DB2962) the sample projects are "Built on STM32Cube software technology, it includes all the low level drivers to manage the on-board devices and system-level interfac...
When power is applied to the STM32L476, 3.3 v is also applied to the LSM303AH pins2 CS9 Vdd 10 Vdd IOThese commands work:MX_I2C3_Init(); Goes to code created by CubeMX HAL_I2C_GetState(&hi2c3); ...
I'm trying to use the MEMS1 microphone streaming example, with 4 pdm microphone and a stm32wb55. I am able to use it to get a 48kHz 16 bits per sample with all the microphones without any issue.But when I try to use 24 bits per sample (I'm not sure t...
Hello everyone,I use NUCLEO STM32F446 and barometer MS5611 with I2C interface. I want to get temperature and pressure data but I am also getting damaged data from USART2. I haven't a problem about baud rate and it is 115200 Bit/s. What is the problem...
Hello,I am trying to set up an FSM on the LSM6DSO, but I have been struggling for several weeks. Upon further investigating the register values, I believe that I might have accidentally written to a memory location that changed something about the FS...
Hello everyone,I am currently looking at the IIS2MDC and the LSM303AGR and I wanted to know what was the accuracy in degrees of these sensors. I want to rotate a camera towards the magnetic north with an accuracy f 1°. Do you know if these sensors co...
