MotionFx ATime, MTime and FrTime Parameter
I'm currently trying to stabilize the MotionFx Sensorfusion in an environment with medium magnetic disturbances. However I don't quite understand the three parameters ATime, MTime and FrTime from the Knobs structure. For example the manual UM2220 des...
ritzmo93 by Associate
  • 1069 Views
LSM6DS3 SPI communication problem with STM32F4
Привіт! У мене проблема з отриманням даних із датчика LSM6DS3. Коли я намагаюся прочитати значення реєстру "WHO_AM_I", я отримую надто короткі імпульси у відповідь, які не можуть бути прочитані поданими до його тактового сигналу.Я використовую цю пла...
DmytroMachkovskyi_0-1716675423212.png DmytroMachkovskyi_1-1716676173880.png DmytroMachkovskyi_2-1716676417924.png DmytroMachkovskyi_3-1716676549564.png
Resolved! Unicleo-GUI datalog's timestamp not working correctly
I'm working with a nucleo 401RE and a x-nucleo ISK 01A3 as hardware and algobuilder and unicleo-GUI as software. If I measure, for example, the rotation vector 9X throughout the day and save the output datalog using Unicleo-GUI, the timestamp shows t...
aesteban by Associate III
  • 1407 Views
Resolved! Issue while configuring the example of lis2dw12 sensor
HiI am trying to configure the accelerometer sensor to read the data polling  as the example suggested in githubWhen I try to read /* Read output only if new value is available */lis2dw12_flag_data_ready_get(&dev_ctx, &reg);At initial the drdy will b...
M4n0j by Associate
  • 2129 Views
Resolved! Getting started with STEVAL-MIC007V1
Hi Everybody, I am a beginner and I need some information to start using the following devices:- Nucleo-F401RE- X-Nucleo-Amicam1- Steval-mic007v1. I have currently downloaded the following material:- X-cube-memsmic1- Link007- Link009- Stm32cubeid.Is ...
OsBo by Associate
  • 1317 Views
spi drives mp34dt05 microphone chip and collects PDM data stream
 I now want to use the spi port of the stm32F407 series to collect data from the PDM microphone of mp34dt05. My SPI is set to the main device to only receive. There are SCK and MISO ports. The SCK clock is 2.25Mhz. MISO receives data, but I found tha...
Daqiang by Associate II
  • 3118 Views
